frame
Simon Jones
frame
#1 PostAuthor: Simon Jones » Tue Nov 15, 2011 8:10 pm
Im going to strip and paint my frame over the winter and i thought id have it put on a jig to check its straight ,has any one got any idea who has got a jig and the tools to do a z1 frame
Simon
75 z1b 75 h2c z1100r rd400 z1000a1 TS125 garelli tiger cross dt400
#2 PostAuthor: kev edwards » Tue Nov 15, 2011 8:27 pm
Just look on the web for your nearst motoliner it's not cheap if they are bent though.
#3 PostAuthor: z1bman » Tue Nov 15, 2011 8:33 pm
try steve smethurst
GUYZED
#4 PostAuthor: GUYZED » Tue Nov 15, 2011 10:08 pm
I'm sure you will need to leave in the engine,swing arm and back wheel.
#449
Z1000A2 Z650B1
Bill Newman
#5 PostAuthor: Bill Newman » Wed Nov 16, 2011 12:33 am
GUYZED wrote:I'm sure you will need to leave in the engine,swing arm and back wheel.
I have just been through this with Seastar Kawasaki - they have a jig and did Rod Gibson's Z.
You have to remove everything except engine and swing arm which has to be taped to the rear down tubes(for set up).
They prefer the rear wheel out.
Cost is £75 for set up on the jig plus £50 per hour for each hour worked. Mine is going in on 3 December, subject to getting the bracing kit in time from Pitstop. RobW is going to help me get it there - about 35 miles from where we live.
I am going to start a thread in the projects section next week when I take the spanners to the bike.
#6 PostAuthor: Ginger Bear » Wed Nov 16, 2011 7:46 am
Simon,
Took my frame to this lot;
http://www.motoliner.com/
It's a bit of a 'day out', but they will do it for you the same day (by appointment). Cost was £70 to check it over, any additional work was charged by the hour.
# 104
