I have had to put the original carbs back on, I just couldn't get the bike to run with the new rebuilt set, it would scream at full revs on full choke, but not run off the choke? so not sure what's wrong there then, I am by no means a carb specialist.
But on refitting the old original block, she fired right up, and runs off the choke, although a litlle on the lumpy side, but that will be sorted come MOT time.
I need to get a new front tyre for the MOT, but everything else looks good to go, well, apart from the front brake line that is! Have a look at the picture to see how the previous owner had run the bike, also what is supposed to run through the loop that is arrowed, is it the tacho cable? if so, then the one I have bought/fitted is too short.
So I will be getting a braided line made up to replace this abomination.
This space for rent ( ........ )
