Front disc
Gus
Front disc
#1 PostAuthor: Gus » Fri Oct 07, 2011 9:19 pm
Evening gents.
Does anybody have a leftover/forgotten/neglected/no longer loved/abandoned front drilled disc they no longer require?
To fit the four bolt Z1000 set up.
Cash waiting
Cheers guys
Gus
"Set the GRINDER on it"
turbokwaka259
#2 PostAuthor: turbokwaka259 » Fri Oct 07, 2011 10:04 pm
Hi there, think I have some disks they fit onto a z1r alloy front wheel 4 bolt pattern but there is 2 different sizes in diameter I will take some measurements and let you know, the disks are in very good condition with little wear, will these be any good?
what can you do to make any bike better? attach a rajay turbo......then hold on for dear hell
Gus
#3 PostAuthor: Gus » Sat Oct 08, 2011 9:37 am
Cheers turbokwaka259.
I would need the 295mm Dia. if you have one.
Gus
tlc
International Rep
#4 PostAuthor: tlc » Sat Oct 08, 2011 11:09 am
Pretty sure I have an undrilled disc.
Asphalt Cowboy
Gus
#5 PostAuthor: Gus » Sat Oct 08, 2011 11:18 am
Cheers Chris.
That will be my next option if I can't find a drilled one.
Ta.
Gus
#6 PostAuthor: paul doran » Sat Oct 08, 2011 11:50 am
Gus I have one Yours free if You can collect at Stafford
Gus
#7 PostAuthor: Gus » Mon Oct 17, 2011 7:27 pm
turbokwaka259 wrote:Hi there, think I have some disks they fit onto a z1r alloy front wheel 4 bolt pattern but there is 2 different sizes in diameter I will take some measurements and let you know, the disks are in very good condition with little wear, will these be any good?
Any luck with the discs?
Paul Doran
Sorry Paul. Couldn't get a pick up sorted as I couldn't make it myself.
Thanks anyway
Gus
