I rebuilt my motor (along with the rest of the bike) last year and this problem was there then and I have since stripped it down for other reasons (mainly a leaking valve guide between head and guide) and while apart I had the crank stripped and balanced by S.E.P kegworth, new pistons and rebore, and some cylinder head work. Also had the clutch springs replaced. I have checked all bearings and for anything obviously damaged/worn (gears, bearings, alternator rotor etc. etc and I really couldn't find a thing wrong) S.E.P also said that all crank bearings were perfect.
This vibration starts at about 4200rpm in any gear and increases as the revs climb and about 5000 it levels off. It happens in any gear and I have noticed it if I rev it at idle. There is no abnormal noises with this except a lovely howl from the exhaust
I have now finished the first stage of running in at no more than 4000 rpm and have now discovered this problem. I mainly feel it through the footpegs and also the seat but not through the tank or handlebars. The bike is standard except for a Marvin 4 into 1 exhaust( I have wondered if this exhaust is the problem).I am also running it with the old points ignition as well.
There is no power loss and the bike pulls through all gears really well. I now need to recheck the shims and carbs after the run in period but I don't think this would be the cause ( it is a bit lumpy on tickover and I can hear a slight rattle from one of the shims at tickover)
As the motor runs so well I don't think its a serious problem but at 60mph and above it just becomes a bit uncomfortable. If this is how Z's are then please tell me. It's been 20 years since I last rode it and I can't remember it like this.
Please help with any suggestions as it is just spoiling what is a fantastic bike . Thanks, Rog
