Heavy "clunk" in gearbox area
kiwiz
#1 PostAuthor: kiwiz » Sun May 06, 2007 1:25 am
Hi,
My old J has been making some heavy " clunking" sounds when it is declutched at low speeds so as to avoid a stall and when clutching again to resume progess. its quite a deep clunk,
I have managed to emulate this by running the bike in low gear on the mainstand. firstly when declutched but in low gear there seems to be significant friction such that application of the rear brake or a very heavy grip with hands is required to stop rear wheel rotation. I assumed that this was just normal friction in the wet clutch. Rolling the throttle on and off slightly with it in low gear whilst clutching and declutching seems to provoke the same heavy "cluncking" noise.
Could it be as simple as just rear chain tension or something more sinister? I have eyeballed the rear chain and that looks fine and earlier I had a lot of problems with the declutching lever over rotating and jamming declutched until I discovered the the Clymer manual only dealt with the worm adjuster and that my ball and ramp system adjustment mechanism was done 100% the reverse!
Bike runs fine under load and clutch seems to operate correctly under normal road conditions. Anything to worry about?
Success is the ability to go from one failure to another without loss of enthusiasm
uk kev
#2 PostAuthor: uk kev » Sun May 06, 2007 7:34 am
Now I am no expert, and may well be way off the mark, but going by your description, I would say have a look at the cush drive rubbers?
Although I reserve the right to be wrong
Garn 1
#3 PostAuthor: Garn 1 » Thu May 10, 2007 8:18 pm
I have had this trouble when the clutch plates were dirty and were gummed-up. I solved the problem initially by just pouring in some "flushing oil/ engine-cleaner product" it freed the clutch and got rid of the "clunk". I later removed all clutch plates and cleaned them. The product was only to be used before an oil change. I later stripped the engine down, it was beautifully clean inside!
RegardZ
classkawa
#4 PostAuthor: classkawa » Fri May 11, 2007 7:26 pm
It isn't just a Zed thing is it? seems to me they all have clunky gearboxes, they are strong but a bit crude and agricultural.
I changed to a 530 chain from the original 630 and that improved things a great deal and gives you access to a bigger selection of chains as it is a more common size.
There was a significant weight difference between the original 630 chain against a modern 530 one as well.
Steady Eddie #21
