Zephyr swingarm to a Z1000
FreddaAbborre
#1 PostAuthor: FreddaAbborre » Sun Sep 18, 2011 8:20 pm
Should fit a Zephyr swingarm to my A2. Is there a way that I can fit it without a need to modify the frame? I'm thinking about the shocks mount, they measure 252mm apart on the frame and 292mm apart on the swingarm. can I make some sort of collar or so that will increase the lenght of the frame mounts?
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
Reecy
Zephyr swing arm fitting
#2 PostAuthor: Reecy » Sun Sep 18, 2011 10:19 pm
Fred,
I did this conversion a few years back on one of my Z1000's, it worked very well, have a look for my thread in the Projects section.
I can't remember what the thread was titled as but it shouldn't be too hard to find
If you need any specifics then get in touch
Regards
Steve Rees
Jappen
Re: Zephyr swingarm to a Z1000
#3 PostAuthor: Jappen » Mon Sep 19, 2011 6:31 pm
FreddaAbborre wrote:Should fit a Zephyr swingarm to my A2. Is there a way that I can fit it without a need to modify the frame? I'm thinking about the shocks mount, they measure 252mm apart on the frame and 292mm apart on the swingarm. can I make some sort of collar or so that will increase the lenght of the frame mounts?
You can ask Morten he have done it :D
80-Z1000H
79-Z1000MK2
FreddaAbborre
Re: Zephyr swing arm fitting
#4 PostAuthor: FreddaAbborre » Tue Sep 20, 2011 6:04 pm
Reecy wrote:Fred,
Regards
Steve Rees
Searched for your nick, but couldn't find anything. Maybe lost in the meltdown?
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
garyd
#5 PostAuthor: garyd » Tue Sep 20, 2011 7:46 pm
I'm fitting one to my Z1000.
You can use the std S/arm spindle and either fit resized bearings or add a sleeve to the s/arm.
For the shock mounts on the frame, I'm going to get new mounting point made up to screw onto the origional mounting that pushes the shocks out so that they line up with the s/arm
Baldylocks
#6 PostAuthor: Baldylocks » Tue Sep 20, 2011 8:13 pm
Hi, Did it on my 650/1100 , sleeved the swing arm pivot and you can space out the top Shock mounts and use thinner Lock nuts from a GPZ11 rear engine mount as they are the same thread..
Bugger ! whose Idea was that!
'78 Z1r '79 z650/1100 '77 Seeley H**** 750 GPz1100 B2 '86 GSXR750R Ltd '97 KTM620 '76 S3a 400
FreddaAbborre
#7 PostAuthor: FreddaAbborre » Thu Sep 22, 2011 7:18 pm
garyd wrote:I'm fitting one to my Z1000.
The fittings for the spindle is not a problem. Have made a bushing to put inside the pivot to use with the std swingarm spindle.
The problem is a new mounting point, how it should look like?!
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
garyd
#8 PostAuthor: garyd » Thu Sep 22, 2011 10:12 pm
I'm going to get a new top mounting pint that is identicle to the origional but has a thicker inner section that has an internal thread to screw onto the origional mounting....I'll try to draw it for you tomorrow.
FreddaAbborre
#9 PostAuthor: FreddaAbborre » Tue Sep 27, 2011 6:40 pm
garyd wrote:I'm going to get a new top mounting pint that is identicle to the origional but has a thicker inner section that has an internal thread to screw onto the origional mounting....I'll try to draw it for you tomorrow.
how is it going with the drawing?
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
garyd
#10 PostAuthor: garyd » Wed Sep 28, 2011 12:12 pm
Ah..Well...I'll do it tonight. :oops:
FreddaAbborre
#11 PostAuthor: FreddaAbborre » Wed Sep 28, 2011 8:16 pm
garyd wrote:Ah..Well...I'll do it tonight. :oops:
Something like this?
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
garyd
#12 PostAuthor: garyd » Wed Sep 28, 2011 8:17 pm
Spot on Fred.
