advice about eng case
baz
#1 PostAuthor: baz » Tue Sep 20, 2011 6:45 pm
sorry don't know how to do the link, but can any one tell if these casings are standard or bored out (ebay 320758062979) is the main cap braced, and could they be used in a standard eng rebiuld....cheers lads
Z1parR
#2 PostAuthor: Z1parR » Tue Sep 20, 2011 6:52 pm
0172 . Geoff Parr
#3 PostAuthor: Ginger Bear » Tue Sep 20, 2011 6:59 pm
Paul has a set of cases for sale, if Z1000 will do?
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=15751
# 104
#4 PostAuthor: Pigford » Tue Sep 20, 2011 7:05 pm
Iop csing doesn't look as its been machined out :?: Hard tpo be sure.
See what you mean about the crank location cap - looks aftermarket - not a bad thing :wink:
hillbilly
#5 PostAuthor: hillbilly » Tue Sep 20, 2011 7:25 pm
naaa there not drilled.
baz
#6 PostAuthor: baz » Tue Sep 20, 2011 8:02 pm
so do you think 900 barrels will fit ok
#7 PostAuthor: Ginger Bear » Tue Sep 20, 2011 9:30 pm
Yup........ No problem.
# 104
Garn 1
#8 PostAuthor: Garn 1 » Tue Sep 20, 2011 11:45 pm
As Pigford says; "hard to be sure" to see from photo's, if cases have been bored to fit the heavier Z1000 bore. However, the standard bores barrels will always fit, albeit, the useless o-rings at the bottom may not be effective.
The main centre bracket does look modified but it may have just been lost and another made up.
baz
#9 PostAuthor: baz » Wed Sep 21, 2011 7:12 am
thanks for that lads :D
#10 PostAuthor: Rich » Wed Sep 21, 2011 6:36 pm
The crank cap has a APE style spreader plate fitted, most likely machined flat under it. Not a bad thing, but I would expect the cases have been bored for bigger sleeves to go with the cap.
