WIRING HELP NEEDED CLUTCH CUT OUT SWITCH FOR STARTING
Padders
#1 PostAuthor: Padders » Fri Sep 09, 2011 6:51 am
Hi I have fitted a differant clutch lever housing on my GPZ1100B1 that does not have a connection for the clutch/starter wiring, the small switch that is depressed when you pull the clutch lever in when started the bike. Can this be bypassed / wired to be on etc. Any advice greatfully recieved.
#2 PostAuthor: Al » Fri Sep 09, 2011 7:04 am
If its wired the same as the H then follow the wires from the switch back to where it joins the loom under the tank and pull those two wires out. Join across and the switch is now out of circuit.
KeithZ1R
#3 PostAuthor: KeithZ1R » Fri Sep 09, 2011 7:08 am
Two black connections under the tank like the man says Ian join em together
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
HowieD
#4 PostAuthor: HowieD » Fri Sep 09, 2011 8:36 am
Padders,
if it is the same arrangement as a Z1-R then the switch MAKES the Starter Circuit when the leaver is pulled in, the other component is the Starter button.
In than case the two wires that the switch would have connected too can be connected together and the Starter button only will make the curcuit.
Regards
Howie
CD185, Maggot, Z1-R, Horace
Padders
#5 PostAuthor: Padders » Fri Sep 09, 2011 8:47 am
Thanks guys for the advice.
