reg/rec number needed
hillbilly
#1 PostAuthor: hillbilly » Sun Sep 04, 2011 11:21 am
does anyone have the correct number on the side of reg/rec for a z1r.ie sh32-12 3.9.shindengen.
Z1parR
#2 PostAuthor: Z1parR » Sun Sep 04, 2011 11:39 am
Hi Brent , mine is SH232-12 0.6 , hope that helps :wink:
0172 . Geoff Parr
hillbilly
#3 PostAuthor: hillbilly » Sun Sep 04, 2011 11:43 am
cheers geoff ,i have two here with different numbers and wires,one off my z1r beasty,and a spare,the trouble is my bike is cooking the battery dry,so want to try a different one.before looking at what else would cause it to do this.
Garn 1
#4 PostAuthor: Garn 1 » Sun Sep 04, 2011 10:37 pm
Hillbilly, I've found, if its a Shindengen and it has 6 wires it will do as regulator/rectifier. Be careful it is not just a small "rectifier only" species.
Check your existing item, with charged battery, whether it exceeds 14.5 volts at approx 4000 RPM.
hillbilly
#5 PostAuthor: hillbilly » Mon Sep 05, 2011 3:59 pm
cheers garn1 :wink:
#6 PostAuthor: Rich » Mon Sep 05, 2011 7:44 pm
H**** Superdream and a few other models are SH232, Kawasaki MkII are SH230-12C either will work (or just about any other type that is 12v and has voltage sensing). As Garn says should only reach 14.7 v @ 4 / 5K
Z1parR
#7 PostAuthor: Z1parR » Mon Sep 05, 2011 7:50 pm
A Superdream reg/rec on my Z1R , how very dare you :wink:
0172 . Geoff Parr
hillbilly
#8 PostAuthor: hillbilly » Mon Sep 05, 2011 7:58 pm
Rich wrote:H**** Superdream and a few other models are SH232, Kawasaki MkII are SH230-12C either will work (or just about any other type that is 12v and has voltage sensing). As Garn says should only reach 14.7 v @ 4 / 5K
rich,i think i must have a wet dream reg/rec,with 232 start number,only trouble is ,its got two leads coming out it.three yellow,and red/black/green.the other that came off my beasty bike has one six pin plug. :shock:
