Wots Cooking
sanderz
#31 PostAuthor: sanderz » Tue Aug 16, 2011 6:57 pm
First fings first an all that - music?
http://www.youtube.com/watch?v=Acmb6tk0Yj4
Hard to handle? you decide....
Backtrackin' slightly (pre meltdown) some might remember the front mudgaurd im using - Suzuki RF900, bought from a breakers for a fist full of Yen ( well ...£15 actually) Reason being couldnt find a decent Yam FZR one an this wasnt far off the right dimensions.
Had it sprayed locally for a trade of a few beers (cheers Andy) in 2 pack and then made a fork brace to mount it - material blagged from M&A sheet metal (cheers Smett)
Anyhow that was all sooo last year an finally got round to doin' summat with all these bits an bobs.
Before
Wots up DOHC
sanderz
#32 PostAuthor: sanderz » Tue Aug 16, 2011 7:04 pm
And today its on ....
Had some doubts about the headlight brackets when first put them on,looked miles too far out, but after putting the clock bracket on......
well.... i'll have to see how it looks when the clocks are in.
Wots up DOHC
sanderz
#33 PostAuthor: sanderz » Tue Aug 16, 2011 7:15 pm
Still have to cut the neoprene foam for the clocks and sort the wires out (kin wires :swe :? :grr :confu - me - eleck trickery - :down )
Anyhow, tiz another day tiz that
Soooo, thought as the bike aint in the kitchen no more (if were cookin' is it a barbeque then?) i put the zorst on - as Jim Carey would say "like a glove"
Wots up DOHC
sanderz
#34 PostAuthor: sanderz » Tue Aug 16, 2011 7:23 pm
I can now sort out the rear hanger bracket (another Yam item) i'll need to cut it about a bit and have it rewelded and also sort the rear footpegs.
Slowly coming together tho'
Having sat on it with the rearsets where they are, im happy to measure up for the rear brake line ..... one day (lazy bastard yeh see)
Wots up DOHC
sanderz
#35 PostAuthor: sanderz » Tue Aug 16, 2011 7:26 pm
So thats the story so far (yeh i know - like War an Peace ha ha)
So untill the next time
Sod it .....going for a pint
Latoz
Wots up DOHC
sanderz
#36 PostAuthor: sanderz » Wed Aug 24, 2011 2:54 am
http://www.youtube.com/watch?v=yMazI2RO ... re=related
Masterplan? Ha if only ... :roll:
Now that the front ends on, ive realised when the clocks were on they 'sat' too flat and needed kicking up more. After giving it some thought (a minute with a tab an scratch of the nads) i recond on cutting some inch bar and with a bit of drilling, spot facing an a tickle with a file summat could be done......
several hours & loads of brews later and i had summat that looked 'half right'
First idea was to make some blocks and just sit them on the yolk bracket, but..... theres always a but isnt there.... after placing the rev counter on there found that the cable was a little tight, ah well.
So this is how it ended up -
Wots up DOHC
sanderz
#37 PostAuthor: sanderz » Wed Aug 24, 2011 3:02 am
Some added rubber bushes then raised the clocks slightly (the 3" risers werent helping here :roll: ) admittedly could of done with more of a kick angle but.... well yer makes yer choice an stick with it.
Wots up DOHC
sanderz
#38 PostAuthor: sanderz » Wed Aug 24, 2011 3:16 am
A while back id bought a chain riveter (Machine Mart made by Laser) about time i used it.
So with the chain on (im just gonna quote wots on the box here) a DID 50VM X Ring i could check frame / tyre clearances.
Front sprocket 18T 5/8 offset
Rear 40T
Wots up DOHC
sanderz
#39 PostAuthor: sanderz » Wed Aug 24, 2011 3:29 am
Rear wheel is GSXR1100M
The rear sprocket carrier was machined down 7.5 mm to bring it in line.
Its close between frame and tyre but it has 'even' clearance on both and the chain run is straight.
Right thats me for now, probably look at the exhaust hanger next (need to cut it about and have it rewelded) amongst other odds n sods .......think im just putting off the wiring for now ....... but it'll have to be done.
I'll give it some thought........
Latoz
Wots up DOHC
GUYZED
#40 PostAuthor: GUYZED » Wed Aug 24, 2011 4:32 am
Very nice how you got around the problem of the clocks there sanderz :up keep the up dates coming.
P.S. couldn't you sleep :?:
#449
Z1000A2 Z650B1
sanderz
#41 PostAuthor: sanderz » Wed Aug 24, 2011 11:29 am
GUYZED wrote:Very nice how you got around the problem of the clocks there sanderz :up keep the up dates coming.
:up Cheers Guyzed and no....... too much caffine ha ha
Wots up DOHC
FreddaAbborre
#42 PostAuthor: FreddaAbborre » Fri Aug 26, 2011 11:46 am
sanderz wrote:Image
How have you got the surface on the engine covers? Sand blasting? How will they withstand normal use of the bike (not have the pores filled up with grease/dirt?)
What bike are the forks from? You happen to know the length?
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
sanderz
#43 PostAuthor: sanderz » Fri Aug 26, 2011 3:19 pm
FreddaAbborre wrote:How have you got the surface on the engine covers? Sand blasting? How will they withstand normal use of the bike (not have the pores filled up with grease/dirt?)
The engine cases / covers were glass bead blasted then painted in high temp silver - dont know how they'll stand up to road use. Already got some doubts having recently put the alternator in with grubby hands :| time will tell.
The forks measured 780mm from top to spindle. Yamaha FZR1000 Genesis 1988 (41mm) Think later Exup are 43mm.
Complete front end - yolks, forks, wheel & discs are Genesis. Mudgaurd is Suzuki RF900.
Hope this helps
Wots up DOHC
FreddaAbborre
#44 PostAuthor: FreddaAbborre » Sun Aug 28, 2011 11:23 am
Hope this helps
Thanks a lot!
With paint it shouldn't be much of a problem with dirt on the covers.
Z1 Moto Martin
Z1B
Z1000 A1
Z1000 A2
Z1000 MkII
H**** FT500
#45 PostAuthor: Pigford » Sun Aug 28, 2011 2:08 pm
sanderz wrote:Rear wheel is GSXR1100M The rear sprocket carrier was machined down 7.5 mm to bring it in line.
I got a 17/180/55 Suzook rear wheel - and had 5mm taken off the carrier on the Mk.II :wink:
....looks well sick :twisted:
