DROUIN Supercharged Z1000.
#316 PostAuthor: chrisNI » Thu Jun 30, 2011 3:47 pm
zed1015 wrote:Nearly there.
Just need blasting to match the rest of the blower.
Should be able to get the carb fitted by weekend ,Then it's Play time :D ( If it ain't raining ).
What are the chances.... :cloud :storm this year has been terrible here so far since April. Got soaked this morning going to collect mine but it's nice now.
ollie
#317 PostAuthor: ollie » Thu Jun 30, 2011 4:00 pm
Brilliant bit of craftsmanship ,wish i could weld like that . :wink:
#318 PostAuthor: zed1015 » Fri Jul 01, 2011 3:04 pm
Finally fitted.
Made up a new throttle cable and installed an adjustable main jet and it fired first kick.
Everything misses (Just).
Now just got to wait for the rain to stop :( .
nanno
#319 PostAuthor: nanno » Fri Jul 01, 2011 3:50 pm
That is looking awful...
...ly good! :twisted:
firyembers
Custard Creem
#320 PostAuthor: firyembers » Mon Aug 01, 2011 12:10 am
Loooovely build,that's a work of art.Nice. :rocks
Did you sort your bouncy gauges you never mentioned again,i found a 10/15 thou drilled hole in a blanked adapter dampened enough to be responsive without the bounce. :bng
Nice idea for the chain guide,is it bog std ptfe nylon in black
I just deleted my 30 yr collection of sheep porn :boom and replaced with it your build ImageImageImageImage
Would love to purchase since you now have it on sale,but it would be wasted standing.
This beast needs to be ridden and ridden hard n fast 24/7 not looked at Image
Plus i have a beast of my own that need TLC and thats more than enough to provide satisfaction :l1ck
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
#321 PostAuthor: zed1015 » Mon Aug 01, 2011 12:48 pm
firyembers wrote:Did you sort your bouncy gauges you never mentioned again,i found a 10/15 thou drilled hole in a blanked adapter dampened enough to be responsive without the bounce. :bng
Bouncy gauge is now kaput :( .(The bourbon tube eventually split a couple of days ago during a high speed fly past :lol: )
It did come with an in line restrictor/damper but the gauge was just sh*t quality (Auto gauge) anyhow so now looking for something of decent quality and glycerine damped.
Chain guide is black Polyethelene.
First one i made on the Wakisaki is showing no sign of wear after ten years use.
firyembers
Custard Creem
#322 PostAuthor: firyembers » Mon Aug 01, 2011 1:55 pm
This should do you then,may be a bit big though being 50mm,but they are available in 25-30mm glycerine filled and bottom or back entry connection in 1/8th or 1/4 bsp sizes :lol:
#323 PostAuthor: zed1015 » Mon Aug 01, 2011 2:18 pm
firyembers wrote:This should do you then,may be a bit big though being 50mm,but they are available in 25-30mm glycerine filled and bottom or back entry connection in 1/8th or 1/4 bsp sizes :lol:
Am i missing something ? A link maybe ??? :?? .
I looking for a 52mm 0 to 30psi gauge (No need for vac reading) with rear connection.
firyembers
Custard Creem
#324 PostAuthor: firyembers » Mon Aug 01, 2011 2:27 pm
Yes you are because i did not paste the link :roll: :lol:
http://www.ebay.co.uk/itm/Pressure-Gaug ... 4aad53cfaf
No 50mm 30psi glycerine filled on eBay at the moment though
firyembers
Custard Creem
#325 PostAuthor: firyembers » Sat Aug 13, 2011 4:39 pm
Hi Zed 1015
Found this link,with pretty good prices for your liquid filled gauge.if you not found another source.
http://www.jegs.com/p/JEGS-Performance- ... 0/10002/-1
#326 PostAuthor: zed1015 » Sat Aug 13, 2011 8:43 pm
firyembers wrote:Hi Zed 1015
Yes! Seen those but they don't do liquid filled smaller that 63mm and can't find anywhere that does so looks like i'll have to risk another none liquid one, but a good Auto Meter one this time and see what happens.
Gus
#327 PostAuthor: Gus » Sat Aug 13, 2011 8:51 pm
"Set the GRINDER on it"
firyembers
Custard Creem
#328 PostAuthor: firyembers » Sat Aug 13, 2011 8:56 pm
I found some on sale at Grainger otherwise they retail around the $50 mark.
Buy a few,the annoying thing i had 6 glycerine left over from a job years ago i was saving and they got lost in the many house moves bummer
http://www.grainger.com/Grainger/Pressu ... Pid=search
Although Gus's link will work out better..
dragracer1260
#329 PostAuthor: dragracer1260 » Thu Sep 22, 2011 4:44 pm
zed1015 wrote:
firyembers wrote:Yes! Seen those but they don't do liquid filled smaller that 63mm and can't find anywhere that does so looks like i'll have to risk another none liquid one, but a good Auto Meter one this time and see what happens.
I'm sure I bought my one from Think Automotive in Twickenhan but it does show vac as well which is handy when running a blower when crusing
Nick
