Z750 e1 wiring help
johnyt
Z750 e1 wiring help
#1 PostAuthor: johnyt » Wed Aug 03, 2011 8:34 pm
Hi Guys
Struggling a little on my rebuild now I am upto the wiring.
On the right hand side where the timing system sits there are three wires from the unit. Does anyone know where they go to please
cheers
johnyt
#2 PostAuthor: z1bman » Wed Aug 03, 2011 10:00 pm
what colours are the wires + do they come from the right hand side of the engine when you are sitting on it
johnyt
Z750 e1 wiring help
#3 PostAuthor: johnyt » Thu Aug 04, 2011 8:05 pm
Hi There
Yes sitting on the bike the wires come from the right hand side and the colours are, green/red, black/white, and blue/red.
many thanks
johnyt
#4 PostAuthor: z1bman » Thu Aug 04, 2011 10:47 pm
these wires should be connected to the cdi unit which is located behind one of the side panels
Z1parR
#5 PostAuthor: Z1parR » Thu Aug 04, 2011 11:19 pm
The wires should be routed under the right hand side of the engine, then run up behind the gearbox past the brake switch and behind the right side panel .
0172 . Geoff Parr
Crofty
#6 PostAuthor: Crofty » Fri Aug 05, 2011 9:09 am
One may be for oil pressure switch, located below the end of rh crankshaft below ignition pickup plate. Blue and red wiring I think.
