Generator rotor tool
Does anyone have the generator rotor tool to suit my 1000 A that I could borrow please?
Asphalt Cowboy
Ever the resourceful type I made a slide Hammer out of the swing arm spindle however screwing it in tight and LIGHTLY taping with a hammer whilst pulling will remove it . Make sure the bike is facing North/South
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
KeithZ1R wrote:Ever the resourceful type I made a slide Hammer out of the swing arm spindle however screwing it in tight and LIGHTLY taping with a hammer whilst pulling will remove it . Make sure the bike is facing North/South
dont forget to remove the battery earth too! or this could happen
(\__/)
(")_(")
(")_(")
- Chunks
front wheel spindle fits, also the bolt that holds the top yoke down will fit, hold the rotor with a chain and rachet that used to remove oil filters from cars can be done in minutes this way just keep tightening the bolt and it will pop off if you can borrow mine if you do not have the tools to this job or i can come over to your house
- Chunks
