help with Z1R exhaust gasket
bedlow1
#1 PostAuthor: bedlow1 » Sat Apr 28, 2007 11:46 am
Can somebody help! I am so near fitting a genuine exhaust to my bike, the only problem is that a important gasket seems to be no longer available. The part no. is 11009-1035, without this gasket the silencer is very loose fitting to the Box. I cant tell what this is made of to make a copy or wether it fits inside the box or over the outlet.Have any of you any ideas? its item 21 on the diagram. ta bedlow
stale
#2 PostAuthor: stale » Sat Apr 28, 2007 1:29 pm
It's superseeded. Try ordering 11009-1629 or 11060-1095. They're for the 1200 Voyager.
72 H2,99 W650,72 H1C,76 KH250,75 F11,70 G4TR,78 KV75,76 KV80R,71 MT1
#3 PostAuthor: paul doran » Sat Apr 28, 2007 2:58 pm
Graham i got your pm
unfortunately my Z1R no longer has the standard exhaust fitted
Jeff Saunders
#4 PostAuthor: Jeff Saunders » Sat Apr 28, 2007 3:22 pm
If you can't find a genuine part, it will be fairly easy to either make one or adapt one from another bike. If you measure the diameter, you can match up to a few we have http://www.z1enterprises.com/SearchResu ... connecting
or give us the dimensions and we'll try and find something you can use.
The ones I see in our supplier catalogues range from 35mm internal diameter all the way to 43mm internal diameter
bedlow1
#5 PostAuthor: bedlow1 » Sat Apr 28, 2007 3:27 pm
stale and paul , many thanks have ordered a 11060-1095 as the other one was also no longer available, its quite pricey at ?16 +Vat but neccessary. have to wait a few more days now to get exhaust on.
bedlow1
#6 PostAuthor: bedlow1 » Sat Apr 28, 2007 3:29 pm
thanks as well to jeff, have ordered a kawa one but will contact you if it doesnt work
bedlow1
#7 PostAuthor: bedlow1 » Thu Jun 07, 2007 7:10 pm
All done now. With Marshall off and original on its so quite
Padders
#8 PostAuthor: Padders » Thu Jun 07, 2007 7:16 pm
Looks a treat mate.
padders
davejames
#9 PostAuthor: davejames » Thu Jun 07, 2007 10:46 pm
Looks great, nice to see a standard exhaust and full length mudguard have survived :shock: :shock:
Ed Z1-R
#10 PostAuthor: Ed Z1-R » Fri Jun 08, 2007 7:12 am
Pukka Z1-R that :up
