Want - Carb rubbers - GPz/J
#1 PostAuthor: Pigford » Sun Jul 24, 2011 3:51 pm
Anyone got any New/As New inlet manifold rubbers - larger GPz style please - for sale :?:
mattc
#2 PostAuthor: mattc » Sun Jul 24, 2011 5:44 pm
Yup, I have x4 used ones from my J2 if you want them, they have been sitting in the departure lounge (next to bin) for a few years now. They were fine pre last rebuild, I only bought new to be sure to be sure to be sure.....actually I thought our role in life was to keep Z-Power in busines.
pm me if you want them. Matt :D
Matt C
Z1000J2 / ZRX1200R / Z650B1 / GPz1100B1 x 2
ZKEN
carb rubbers
#3 PostAuthor: ZKEN » Mon Jul 25, 2011 2:50 pm
pm sent
KAWA ZRX 12R
RD400E
RD200E
#4 PostAuthor: Pigford » Mon Jul 25, 2011 6:29 pm
Cheerz ZKEN - Sorted now thanx
Jeff Saunders
#5 PostAuthor: Jeff Saunders » Tue Jul 26, 2011 12:10 am
There are two different version of these... so make sure they match the carbs. When you look at the carb spigot that goes into the carb holder, there's a groove running around it that a corresponding rib on the carb holder matches. The early versions have an evenly radiused groove about 1/4" from the end of the spigot, the later ones have a wedge cut (triangular cut) much closer to the end.
If you use the wrong ones, you'll split the carb holders very quickly, and have problems getting the carbs to hold inside the carb holders.
#6 PostAuthor: Pigford » Sat Jul 30, 2011 4:59 pm
Ahhhh, thanks Jeff.
I'm running RFS36's and one of the rubbers has a slight leak just by the screw head :!:
Haven't taken it off to see which type of rubber it is yet though - so which is best for my carbs :?:
Also BIG thanks to Mattc - top chap :wink:
mattc
#7 PostAuthor: mattc » Sat Jul 30, 2011 5:25 pm
You are welcome Mark...good to meet up. Let's try for two wheels next time. :lol:
Matt
Matt C
Jeff Saunders
#8 PostAuthor: Jeff Saunders » Tue Aug 02, 2011 11:22 am
Hi Mark, you should be able to see a partial part number on the carb holder end.
You'll see 1135 or 1131
Equates to 16065-1135 (evenly radiused rib inside) and 16065-1131
(triangular wedge rib).
#9 PostAuthor: Pigford » Tue Aug 02, 2011 4:52 pm
Cheers Jeff :wink:
