yolks 2
Keefleaf
yolks 2
#1 PostAuthor: Keefleaf » Tue Jul 12, 2011 8:31 pm
[img][img]http://i315.photobucket.com/albums/ll451/KeefKawa/z1yolks005.jpg[/img][/img][img][img]http://i315.photobucket.com/albums/ll451/KeefKawa/z1yolks004.jpg[/img][/img][img][img]http://i315.photobucket.com/albums/ll451/KeefKawa/z1yolks003.jpg[/img][/img][img][img]http://i315.photobucket.com/albums/ll451/KeefKawa/z1yolks002.jpg[/img][/img]Image
Yolks on blue tarp` and on car wheel,[same pair different backround].
Front one has blanked off steering lock hole but slot in stem.
Back one has steering lock fitted.Neither have hole for steering damper.
Yolk on forks has blanked off steering lock but no slot in stem?Does have
steering damper hole
Yolk in red oxide has a "mirror image " 3 ..date code?
Im confused,can anybody help?
#2 PostAuthor: kev edwards » Wed Jul 13, 2011 8:41 am
The one in red oxide looks to be the type you need, the steering damper on that one fixes up into the centre stem had one on mine, the other two yokes look to be 650 and later model where the locks were on the side or in the ignition barrel, if you use 650 yokes the forks will hit the tank.
#3 PostAuthor: Rich » Wed Jul 13, 2011 6:33 pm
Yolk - The yellow, usually spherical portion of an egg of a bird or reptile, surrounded by the albumen and serving as nutriment for the developing young.
Yoke - A clamp or vise that holds a machine part in place or controls its movement or that holds two such parts together.
Confused - not as much as me :D
Keefleaf
#4 PostAuthor: Keefleaf » Thu Jul 14, 2011 9:35 pm
......Nice one Rich,I`ll take that as a don`know :D
Thanks for the P.M. Gez :wink:
