it hesitates..annoying as hell
P4L08
#1 PostAuthor: P4L08 » Sun Jul 10, 2011 2:07 pm
Hi All
Haven't been here fore a while as I was ill last year and didn't get to ride the Z until the end of the summer.
It has an 1105 kit, gas flowed head and 28mm carbs with a Harris pipe. It runs pretty nicely now with 130 mains although can't remember what pilots are in there 22.5's maybe. Dyna ignitiona and standard airbox.
Anyhow symptoms:
1. little flat spot just off idle makes it a pain in traffic.
2. When riding at constant speed it'll hesitate then pull, hesitate then pull almost like I am opening and closing the throttle.
On a ride up the back roads you don't notice it because you are up and down the box and not running a constant throttle.
Any ideas. I thought maybe jet up to 135's and bigger pilots. Or could it be the advance retard mechanism
thanks
Dale
skoda
#2 PostAuthor: skoda » Mon Jul 11, 2011 8:48 am
sounds like fuel starvation to me check fuel flow from the petcock tank fillter may be blocked
#3 PostAuthor: Rich » Mon Jul 11, 2011 7:14 pm
fuel heights
small pilot feed hole into venturi engine side of the slide - make sure it's clear.
synchronise
I also expect the mains you have in are too big. Put your pilots back to std and play with the airscrew for highest tickover, then try 120 main jets.
