Berkshire meets...2011...
The rest of the years meet dates goes like this:-
June 12th (Today)
July 10th
August 14th
September 11th
At the
Hatchgate pub,
Bramshill Road,
Bramshill,
Near Hook,
Hampshire,
RG27 0JX.
12 Noon start time.
www.thehatchgate.com
June 12th (Today)
July 10th
August 14th
September 11th
At the
Hatchgate pub,
Bramshill Road,
Bramshill,
Near Hook,
Hampshire,
RG27 0JX.
12 Noon start time.
#449
Z1000A2 Z650B1
#449
Z1000A2 Z650B1
- brian 1100
brian 1100
PostPosted: Sun Jun 12, 2011 8:04 pm Post subject:
Al, I'll get Dynotech to do the valves this time but may borrow it for the next time.
How often should they be checked?
Job to know Brian with the miles you seem to get through but i would have thought a check with measure, once a year as part of the annual re-commissioning would be adequate.
Gary have you seen this?
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=11419
And this
http://s254.photobucket.com/albums/hh86 ... ug%202010/
Might find some inspiration in there somewhere.
KS75 about 1/4 way down this page;
Edit; you need to click on 'BADGES/EMBLEMS on the left hand side menu and then select 'Kawaaki' from the menu in the centre of the screen.
http://www.reproductiondecals.com/default_frameset.html
andyrealale
GUYZED wrote:Thanks to Al,Ted,Stu,Brian,Andy,Cliff and Gary that braved the absolutely horrible weather today and made it to the meet...well done chaps
Was nice to meet you all,shame about the weather,still the company, pub and beer made up for it!
We also popped in to visit a mate down the road not seen for years , on the way home.
All in all a good way to spend a Sunday.
Next Berkshire meet is this coming Sunday (the 10th) at the Hatchgate...12.00 noon start.
See you all there...hopefully the weather will be better than last months.
#449
Z1000A2 Z650B1
#449
Z1000A2 Z650B1
tedsonthezed
- brian 1100
I should be there if I'm not too hungover!
Just fitted my CMA rear wheel so it'll be a first ride out with it.
Just adding these photos as a test as I've never uploaded any before
Sprocket drilled out to fit bushes and top hat washers to act as a cush drive.
Not sure how will it will work - the washers a touch to short and the bushes a touch too long.
Wheel fitted with new 240mm disc and ZZR600 caliper
Sprocket side - wanted to drill and lock wire the bolt heads but kept snapping and burning out drill bits so just used lots of locktite instead
The wheel/dics/tyre assembly works out 4.6Kg lighter than the standard wheeel.
See you Sunday
Brian
See you Sunday
Brian
