z9/z1 tank
kwak
z9/z1 tank
#1 PostAuthor: kwak » Thu Jun 16, 2011 12:01 am
hi all can any one tell me which z had biggest fuel tank i am after the early z9 shape i want to keep that shape but what model had biggest fuel tank ie z1000A2
many thanks
andy
DogsbolloxofZ1B
#2 PostAuthor: DogsbolloxofZ1B » Thu Jun 16, 2011 10:36 am
Z900 had the larger capacity and pretty sure it was the same throughout the a1/a1 range too. i.e. effectively the same tank.
jonhunt
#3 PostAuthor: jonhunt » Thu Jun 16, 2011 1:38 pm
I thought the z900 tank was bigger than the z1/a/b
kwak
#4 PostAuthor: kwak » Thu Jun 16, 2011 8:05 pm
DogsbolloxofZ1B wrote:Z900 had the larger capacity and pretty sure it was the same throughout the a1/a1 range too. i.e. effectively the same tank.
I found nice clean one 76 model is that the bigger z9 but it is the american version listed as kz900
hope this is the same
cheers
andy
Garn 1
#5 PostAuthor: Garn 1 » Thu Jun 16, 2011 10:45 pm
Jonhunt, you are correct. Dogs'Z1B is referring to the 1000 A1 & A2 who is also correct.
Also Z900 A4 is same as kz900 not sure about the Z900 LTD.
RegardZ
steve bowdler
#6 PostAuthor: steve bowdler » Fri Jun 17, 2011 6:37 am
If the z900 ltd is the same as the z1000 ltd then it is a lot smaller than standard z900/1000
