hi, a question for the collective please, my 1000 a1 is starting and ticking over ok but on the road it has a misfire /spluttering (i,m sure you all know the feeling)feels like it,s running out of petrol,i,ve cleaned the carbs as best i could but can anyone tell me what exactly what needs to be cleaned other than the pilot and main jet,and tube for same,and the passage at the bottom of the carb bowl
i just want to rule out the petrol side of things first.
for the record , it,s got new fuel cap (venting ok)
new reg/rectifer ok
inline filters to carbs (plenty of flow)
timing is ok,
new air filter
which leaves the plugs and condnsers (running points )
i,ve got sooty plugs on 1 & 2 , and clean on 3 & 4
would faulty condensers cause it ?
next step i,ll fit new plugs and see,also run it without the air filter and see.
thanks in advance knut
