Z1b rear wheel spacer
coldsummer
#1 PostAuthor: coldsummer » Sun Mar 14, 2010 10:28 am
Desperately seeking rear wheel spacer for a Z1b. It's the one that goes between the sprocket carrier and hub, not the other one that looks like a cotton reel. This is the part no; 42036 015 sleeve.
I would be very grateful!!
Alternatively, borrow one to use as a pattern to get another made up?
hillbilly
#2 PostAuthor: hillbilly » Sun Mar 14, 2010 12:16 pm
is it the one that looks like a big washer,the same size as the bearings. :?:
coldsummer
#3 PostAuthor: coldsummer » Sun Mar 14, 2010 3:25 pm
hillbilly wrote:is it the one that looks like a big washer,the same size as the bearings. :?:
Hi Hillbilly - it is about 42mm long with a raised lip in the middle, one end sits inside the bearing in the sprocket carrier and the other meets the face of the hub bearing. It's not the flat one. Cheers, Simon.
#4 PostAuthor: PAULJAC47 » Sun Mar 14, 2010 8:26 pm
May be able to help, will have a look asap Cheers Paul J..... :wink:
coldsummer
#5 PostAuthor: coldsummer » Sun Mar 14, 2010 8:32 pm
PAULJAC47 wrote:May be able to help, will have a look asap Cheers Paul J..... :wink:
Thanks Paul, hope you can, I'm kinda stuck without it :(
Steve Cooke
#6 PostAuthor: Steve Cooke » Sun Mar 14, 2010 9:40 pm
Z-power do them quite cheap.
coldsummer
#7 PostAuthor: coldsummer » Sun Mar 14, 2010 9:51 pm
Steven Cooke wrote:Z-power do them quite cheap.
Thanks Steven, I thought they were NLA, I'll have to give big Phil a call!
coldsummer
#8 PostAuthor: coldsummer » Tue Mar 16, 2010 1:46 pm
Ordered the correct one from Z-power today for about 15 quid, lovely, this should do the trick!
#9 PostAuthor: PAULJAC47 » Tue Mar 16, 2010 6:43 pm
Thats good news Simon, i was unable to find item even though i had a good look through my box of bits....Paul J..
coldsummer
#10 PostAuthor: coldsummer » Tue Mar 16, 2010 8:37 pm
Thanks for looking Paul, worked out ok in the end though!
Users browsing this forum: No registered users and 3 guests
