Carb set up for K & N's
Steve K
#1 PostAuthor: Steve K » Tue Apr 17, 2007 8:12 pm
Just bought a '77 Z900 fitted with K & N air filters, but it's not set up correctly.
Does anybody know what main jet size & needle setting would be needed.
Steve K
Oh' it's also running a 4 into 1 if that makes any difference
uk kev
#2 PostAuthor: uk kev » Tue Apr 17, 2007 8:18 pm
Hi Steve, I was advised to increase the mains by 10% if using pod filters, I asked this same question earlier this week.
#3 PostAuthor: Pigford » Tue Apr 17, 2007 8:22 pm
Steve K, yeeh, +10% (so about 125/130) as a start point. This may err on the rich side, but better that then weak :!:
As for the needles, these will effect 1/4 to 1/2 throttle mixture. Do mains first then start fine tuning with needles after mains are OK. :wink:Some say the standard carbs are a pain to set up when mucking around with hi-flo filters :| Personally I run Mikuni RS flatslides, as they're good to tune, relatively cheap and offer good performance upgrade. Good luck :shock:
Steve K
#4 PostAuthor: Steve K » Tue Apr 17, 2007 8:26 pm
Great help, cheers guys
Steve K
uk kev
#5 PostAuthor: uk kev » Tue Apr 17, 2007 8:27 pm
This was to be my next question on the other thread, but I will ask here as this one is current.
Where do you get the larger 125 mains from?
#6 PostAuthor: Rich » Tue Apr 17, 2007 8:31 pm
Just ring round your local bike shops and see who has Mikuni lets in. You want the round head ones.
Steve K
#7 PostAuthor: Steve K » Tue Apr 17, 2007 8:32 pm
Uk Kev- your local Kwacka dealer should be able get these
#8 PostAuthor: Pigford » Wed Apr 18, 2007 8:25 pm
Make sure you get the large round slotted jets, not smaller hex head ones.
In fact I got some u can have :wink:
PM me ur address UK Kev
Davy Doherty
#9 PostAuthor: Davy Doherty » Wed Apr 18, 2007 8:34 pm
Yet another helpfull Zed head, well done Pigford :wink:
Life's too short!
#10 PostAuthor: Pigford » Wed Apr 18, 2007 8:45 pm
Davy, don't 'big me up' too much, they're only old tatty ones, i've got dozens from me youth when I use to faff around with 2-strokes :|
Wouldn't get much for em on eBay anyhow :?
uk kev
#11 PostAuthor: uk kev » Wed Apr 18, 2007 9:07 pm
Pigford wrote:In fact I got some u can have :wink:
Thanks so much.
Fantastic.
Kev.
uk kev
#12 PostAuthor: uk kev » Fri Apr 20, 2007 9:08 am
Pigford wrote:Make sure you get the large round slotted jets, not smaller hex head ones.
And they arrived today, thanks again Mark.
#13 PostAuthor: Pigford » Fri Apr 20, 2007 7:20 pm
My pleasure UK Kev, now the REAL fun begins :|
uk kev
#14 PostAuthor: uk kev » Sat Apr 21, 2007 2:55 pm
In continuing with the carb theme, on the bank of carbs, I have two fuel inlet stubs that connect to the fuel tap, one for the left bank of carbs, the other for the right bank, then I also have two vacuum stubs, one on each bank again, (A) & (B) now (A) connects to the vacuum stub on the fuel tap, but where does (B) go?
#15 PostAuthor: Pigford » Sat Apr 21, 2007 4:35 pm
Just blank the one furthest from the fuel tap :!: Its just easier for Mikuni to produce 'em like that.
