Swing Arm needle bearing
KeithZ1R
#1 PostAuthor: KeithZ1R » Sat Feb 20, 2010 7:33 pm
Anybody devised an elegant solution to fitting the needle rollers easily :?: obviously a press is the way to go but have no access.
Have a few ideas around threaded rod with turned bushes anythin simpler before I start
thanks boys
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
ruffle
#2 PostAuthor: ruffle » Sun Feb 21, 2010 8:19 am
I turned up a couple of bits of ally and used an M10 rod to pull them in. I'd post a pic
but that'd mean going out in the snow to the toy cupboard :)
If you're really stuck, I could lend you the ally bits via post as they're fairly small
and M10 threaded bar is pretty easy to get hold of.
KeithZ1R
#3 PostAuthor: KeithZ1R » Sun Feb 21, 2010 9:05 am
Thanks Ruffle I was thinking along those lines :) off to the garage to fire up the lathe :!:
Keith
:bop :gom
mistaken.
Rob Lafferty
#4 PostAuthor: Rob Lafferty » Sun Feb 21, 2010 12:26 pm
Keith
I just purchased a couple of plate washers and a threaded bar from a builders merchants. Cost about 3 pounds and job done.
compo z1r
#5 PostAuthor: compo z1r » Sun Feb 21, 2010 12:45 pm
KeithZ1R wrote:Thanks Ruffle I was thinking along those lines :) off to the garage to fire up the lathe :!:
4lb lump hammer do's the trick :lol: :lol: :lol: :lol: :lol:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886
KeithZ1R
#6 PostAuthor: KeithZ1R » Sun Feb 21, 2010 1:02 pm
Yes but dont you haved trouble finding the needles afterwards :lol: :lol:
Keith
:bop :gom
mistaken.
Crofty
#7 PostAuthor: Crofty » Sun Feb 21, 2010 10:05 pm
I used the threaded rod and two end plate method. The pack of threaded rod I bought from screwfix made 5 seperate presses and I sold them on ebay for 3 to 5 pound each. Thinking of approaching Dragon's Den.
Last bearing almost in.
Not sure if your bearings finish flush or recessed, but if recessed you might have to find a suitable socket or thick washer.
ted1r
post
#8 PostAuthor: ted1r » Mon Feb 22, 2010 5:12 pm
I`m with Compo on this ,Big hammer :D
Ted
"Work this is why I did it"
"I've had more minutes than I have left"
Z1R D1
Granada
vantastic Transit........
KLE650
knut
#9 PostAuthor: knut » Mon Feb 22, 2010 6:09 pm
:brav crofty
KeithZ1R
#10 PostAuthor: KeithZ1R » Thu Feb 25, 2010 8:15 pm
Thanks for all the ideas lads I have aquired some m16 threaded bar nuts and washers from my tame engineering co in high wycombe one last question did we all put two bearings in each side as per parts diagram blowup or is it just overkill
Keith
:bop :gom
mistaken.
Crofty
#11 PostAuthor: Crofty » Fri Feb 26, 2010 10:33 am
I can only speak for my Z650, which has 2 each side. If Kawasaki designed it to have 2 in, I would definately put 2 back in. You are far better having the forces spread between 4 than 2, they would wear out too quickly. I have just had a quick look online at a parts catalogue and the 1979 KZ1000 have 2 each side, you did not say what bike you are fitting them to.
Another thing I did was to heat the swingarm in wify's oven about 100 for 10 mins(don't get it too hot, just warm) and I had the bearings in the freezer for a couple of hours and greased the outside of the bearings lightly.
KeithZ1R
#12 PostAuthor: KeithZ1R » Sat Feb 27, 2010 5:33 pm
All sorted now lets hope fitting the arm to the Mk2 was as easy as fitting the bearings :lol:
Keith
:bop :gom
mistaken.
