Is there a gauranteed cure for stuck rings?
Have a good condition 1015 barrels and pistons that have come from US, stood ages and all gummed up.
All but 1 x ring have freed off with the use of carb cleaner, heat etc.
One is stuck fast. and refuses to move after a month imersed in xylene.
Any ideas?
Tom
Stuck rings - Need unstuck rings
TomParkes
TheBogieMan
Iain marshall
Hi Tom dont laugh but this worked for me,an old pot filled with water on the cooker and bring to the boil,then place piston in pot with a bit of welding wire attached,leave to simmer for a couple of mins,then remove if your lucky the ring will have started to come out of the grove,if not gently ease ring out with a small screwdriver,remember and wear gloves or similar when handling piston
