Mikuni RS38 Flatside Set Up?
#1 PostAuthor: Ginger Bear » Tue Feb 16, 2010 8:34 pm
Right then, got a brand new spanking set of 38mm Flatslides & some new K&N filters. I plan to fit them to my Z1000 (Money Muncher Project)
Question is, where do I start jet wise?
Bike is bored to 1105cc, zorst is nothing much (straight through, shotened can)
I was planning to start with 135 main jets & 117.5 pilots, leaving the needle circlip somewhere in the middle.
Any thoughts :?
# 104
#2 PostAuthor: Pigford » Tue Feb 16, 2010 8:54 pm
Thats about the std (as they come from the factory) - but I think 17.5 pilots will be a better bet :wink:
http://www.mikuni.com/fs-carburetor.html
Great read - got loads on info & the std set up for the RFS38 to start from.
#3 PostAuthor: Ginger Bear » Tue Feb 16, 2010 9:44 pm
Pigford wrote: but I think 17.5 pilots will be a better bet :wink:
Thanks Piggy, must have been a bit over excited when I typed 117.5 :xbou
# 104
nanno
#4 PostAuthor: nanno » Wed Feb 17, 2010 9:26 am
Sounds reasonable... Did you enlarge the ports and fit bigger valves as well ? If so, expect to go a bit higher.
Maybe also get a little selection of jets... let's say down to 130 (just for cross-testing) and up to somewhere around 145.
Greg
#5 PostAuthor: Ginger Bear » Wed Feb 17, 2010 10:12 am
Forgot to say, ports have been 'cleaned up' a little.
I do have 130, 135 & 140 jet's in my arsenal.
# 104
nanno
#6 PostAuthor: nanno » Wed Feb 17, 2010 11:54 am
Then just throw them onto the bike and see what happens. :wink:
Greg
neilbarrett
#7 PostAuthor: neilbarrett » Sun Feb 21, 2010 9:08 am
id have it set up on a dyno
#8 PostAuthor: Ginger Bear » Sun Feb 21, 2010 10:41 am
neilbarrett wrote:id have it set up on a dyno
Neil, ultimately that's the way I will go, however the bike has only covered a couple of hundred miles since being re-bored & I have too much mechanical sympathy to see it ranted to bits on a dyno so soon.
I have had two bikes dynoed (ZZR1100 & ZZR1200) & it is certainly an experience being in the dyno room while it's done.
# 104
steve.w
#9 PostAuthor: steve.w » Sun Feb 21, 2010 11:37 am
had my 1100 uni dyno-ed it is good seeing ure bike flat out in top without moving :shock:
