JET SIZES
dimble
dimble
You could do worse than buy these to set up the carbs and in particular the 'air' (fuel) screws.
http://www.ekmpowershop20.com/ekmps/sho ... s-25-p.asp
This is a special offer which saves a few quid!
As a general guide to setting up the rest and interpreting what you get with the above mentioned you might follow this.
http://www.mikuni.com/fs-tuning_guide.html
Do you mean painting the exhausts??
You can tell a lot about initial temperature gains by putting candle wax on the uppermost exhaust stud of each cylinder and seeing which come up first and of course last.
Also useful if youve got a cylinder down and dont want to burn youre hands.
Someone told me about pointing each exhaust and measure the temp and adjust...
