Piston Install Tool
Crofty
Piston Install Tool
#1 PostAuthor: Crofty » Fri Jan 29, 2010 8:39 am
The time is coming where I will be rebuilding the top end on my Z650, does anyone know where I can borrow or buy the tool that holds the pistons and rings while the barrel is lowered on. Crofty
steve f
#2 PostAuthor: steve f » Fri Jan 29, 2010 8:44 am
you have fingers all you need is a small screwdriver and a bit of paitaince
I love old paul doran
ade woollams
#3 PostAuthor: ade woollams » Fri Jan 29, 2010 8:51 am
just bring the 2 middle pistons up do them and then the other 2 (MEER CAT SIMPLES ***** )
#4 PostAuthor: PAULJAC47 » Fri Jan 29, 2010 4:50 pm
Use plastic bottle like used on road race cycles for water cut into strips and retain with tye wraps,or like the other lads say user fingers and a couple of wooden clothes pegs....Paul J...if you want proper tool contact Jerry ...
