Hi All just finishing installing my repro loom have noticed that the loom has a 6 pin input for the ignition switch 4 pins, the top 4 colours match but 2 pins are left empty,checked a mates original on his z1 and both ends are 4 pin! any one else noticed this? what are the two extra wires for in the loom?
Any input welcomed on this....Paul J..
Repro Loom Ignition 6pin connector
PaulJac, I think you will find you have a Z1000 harness. It still may surfice though. Those extra wires are for that useless hazard relay. Check to see if there is provision on the harness for the (z1000/ z900) three-fuses box at the control panel. Also check the harness connector for the LHS switch block. That is probably a 6 pin connector too.
It may be "one harness fits all" combo, otherwise I would return and get a Z1 series replacement.
Thanks Garn1 it is supposed to be a direct z1b replacement i got from the states everything else seem to tie up,it is the sinlge fuse type,will juice it up and see what works and what does not,Thanks Paul j...
Thanks GEZ,bike is coming along well since you last saw it should not be too long b4 i get her going,Cheers Paul J..
