fork dismanteling
fork dismanteling
i am haveing trouble undoing the bolt in the bottom of the fork legs so i can seperate the legs from the stancions on my z650, i have tryed the broom handle trick but still wont budge, i am begining to think that somebody has put them together using threadlock, i was wondering if anybody has any other suggestions or the propper fork holding tool i could borrow. I have spent two afternoons trying to get them apart and took them to my local bike shop but they only had the tools for yamaha forks which we tryed but did not fit, thanks
Chris
Chris
- london calling
- Regular Poster
Had the same problem.
Held the top of the forks in a vice - with rags to protect. Then wound the pressure up on the compressor and out they came using an airgun. Inner did not have a chace to spin.
Only problem is doing them up again. Need to find a tool of some form. May look to make something this afternoon.
Rob
Rob
Chris, I had same trouble with my 650 ones recently. In the end and a lot of trying, I used a large easyout on the end of a couple of long extensions and it was out in under a minute. I inspected the cylinder piston unit afterwards and does not seem to have done any damage, no marks. Jim
ps did you get m/c OK
- paul doran
I had the same problem when trying to overhaul the forks on my KH250 and ended up making the tool. Which I think is fairly close to a 12mm socket. This was discussed recently on here. It was mentioned before by "Pigford" about using one of those adjustable multi sockets that works by having sprung loaded pins inside.
LE to JOG on a z900
P.U.M.
P.U.M.
- paul doran
- paul doran
