COILS EARTH
COILS EARTH
Do dyna coils earh on frame from mounting bolts?
Bit confused on this thread i assumed the coils were earthed through the mounting bolts to the frame but i was going to run an extra ground wire to the frame anyway,some replies on this thread say to put insulators between the coils and the frame?.....!!!!!!!
See what you mean bear, that bottom terminal is very close to the mounting bolt will put some sleeving to stop shorting of low tension terminal to frame do you think its a good idea to run an extra ground wire from the coil metal core to the frame and not just rely on the mounting bolts?
