Paddock stand help
scott
Junior Section leader
Paddock stand help
#1 PostAuthor: scott » Mon Jan 04, 2010 8:58 am
Hi Guys, i hope you all had a good chrimbo?
My 78 Z1000A2 has a Metmachex deep braced swingarm (with bobbins) and also has standard 4 into 4 pipes from a 900. My trouble is finding a paddock stand that i can use that is thin enough to get in between the pipes and swingarm. Does anyone have any ideas? Surely there must be someone out there who has had a similar issue?
#2 PostAuthor: chrisu » Mon Jan 04, 2010 3:26 pm
Scott,
have you looked at ABBA stands - pivot on the swingarm - only stand i can use with my single side swinger Z1R.
Lots of adapters so you can use it on all sorts of bikes - i also use it on the Tuono.
http://www.abbastands.co.uk/
scott
#3 PostAuthor: scott » Mon Jan 04, 2010 3:31 pm
Hi Chris,
i have seen a abba stand being used and the only thing that put me off is the possibility of the swingarm bolt getting scratched. Does that happen with yours?
BShaw
#4 PostAuthor: BShaw » Mon Jan 04, 2010 4:19 pm
Abba is good for Zed, in fact any bike, can't comment on scratching pivot as it wouldn't notice on mine, you could always bolt a centre stand on to do the work
Baza
scott
#5 PostAuthor: scott » Mon Jan 04, 2010 4:37 pm
I can't use an abba stand due to the gear selector linkage being in the way....i've got rearsets fitted (i've just remembered ). I cannot use the centre stand due to the deep brace of the swingarm gets in the way. Nothing's straight forward is it?
#6 PostAuthor: chrisu » Mon Jan 04, 2010 6:10 pm
they also do a footrest bolt adapter........... have a look at the website.
Mark Stratton
#7 PostAuthor: Mark Stratton » Tue Jan 05, 2010 9:27 am
Scott
I've got a paddock stand that I used to use on my NS400R (I know its a H****a but I have seen the error of my ways) and I'm not a million miles away from you so your welcome to come over and give it a try. I'm sure that it could be modified quite easily if required.
scott
#8 PostAuthor: scott » Tue Jan 05, 2010 12:10 pm
Hi Mark.....you have a pm.
