Z1000J Clock Rubbers
#1 PostAuthor: PAULJAC47 » Sun Jan 03, 2010 9:32 pm
Hi All, anyone know where i can get a set a clock mounting rubbers for a 81 z1000j(the large circular ones that go between the clock./rev and its base)or a viable subtitute...Paul J..
#2 PostAuthor: Al » Mon Jan 04, 2010 8:23 pm
Hello Paul sorry as i said i only have the ones i have on mine but:
As you might be able to see they are lengths glued at the ends.
I was thinking along these lines if you see what i mean.
http://www.woolies-trim.co.uk/p-1690-ru ... tread.aspx
If you need dimensions let me know.
Pasc
#3 PostAuthor: Pasc » Mon Jan 04, 2010 9:25 pm
I've seen some home made ones that were made by cutting a ring from high density foam rubber and were quite good. I'm not sure the method used for cutting them though.
