Anyone ever fitted a JMC arm to a Z1B
martinz1b
#1 PostAuthor: martinz1b » Sat Jan 02, 2010 4:20 pm
I have just restarted the long term rebuild of my Z1B. I bought a JMC un-braced swinging arm to improve things at the back end. I have hit a snag, when the rear shocks are fitted the arm comes into contact with the rear footrest mountings. Without heating and bending them outwards is there an easier option such as shorter rear shocks.
Would shorter shocks alter the handling in a bad way? if not does anyone know of shorter shocks that would fit.
Thanks for any advice
Mart
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Sat Jan 02, 2010 4:33 pm
Dont go shorter on the shocks unless you drop you're forks the same amount as it will affect the handling. Dropping both ends the same amount wont be detrimental to the hanlding but will reduce your ground clearnace when cornering.
Sorry to hear about the JMC they never seem to fit first off. I had a braced one in the a1 and hade to modify the brake actuating arm to clear the swing arm. Eventually got rid of it and am looking for an unbraced one without eccentric adjusters.
Good luck with the fitting,
z650 shocks would fit and may be shorter but you would have to check the lenghts.
martinz1b
#3 PostAuthor: martinz1b » Sat Jan 02, 2010 4:43 pm
Thanks KWACKERZ1 I thought altering the shocker length would affect it badly. It looks like either bending them out or taking about 3mm off the rear of each exhaust mount :evil:
Mart
paulmceleney
Chunks
#4 PostAuthor: paulmceleney » Sat Jan 02, 2010 6:03 pm
I have a braced jmc that i tryed to fit to my z900 a4 had the same problem ,to fix this it ment cutting the frame where the rear foot rest are so i change my mind did not want to do this to what once was a standard bike i still have it its now in the loft it will fit a z1000 a1 a2 but not the 900
martinz1b
#5 PostAuthor: martinz1b » Sat Jan 02, 2010 6:12 pm
paulmceleney wrote:I have a braced jmc that i tryed to fit to my z900 a4 had the same problem ,to fix this it ment cutting the frame where the rear foot rest are so i change my mind did not want to do this to what once was a standard bike i still have it its now in the loft it will fit a z1000 a1 a2 but not the 900
The more I look at it I could get away with shaving a few mm off the rear of each footrest mounting, it wouldn't affect the looks at all. What a pain in the arse, I have now struck JMC off my list of good suppliers :drill
#6 PostAuthor: Rich » Sat Jan 02, 2010 7:12 pm
Is that a JMC arm bought new from JMC to fit your bike? If so don't be put off with shoddy workmanship and trying to make something fit which was actually bought to fit - send it back.
If not (and it was a may or may not fit / I think I've measured it right, but the price was right ) bend the footrest mounts out :D
martinz1b
#7 PostAuthor: martinz1b » Sat Jan 02, 2010 7:51 pm
Rich wrote:Is that a JMC arm bought new from JMC to fit your bike? If so don't be put off with shoddy workmanship and trying to make something fit which was actually bought to fit - send it back.
It's a NOS one I bought off Ebay from ZPower for £150 so sending it back is probably not on the cards. I will just have to work on the frame slightly. No wonder Zpower sold it cheap :(
I have just had the frame painted so I don't want to do anything to ruin the finish if I can get away with it.
paulmceleney
Chunks
#8 PostAuthor: paulmceleney » Sat Jan 02, 2010 8:05 pm
IF its not a standard bike cut the trangler part of the frame off that hold the rear foot pegs on you can keep them and always have them welded back on you know you want to i would of done this but i also have a zed 1000 with a jmc fitted
martinz1b
#9 PostAuthor: martinz1b » Sat Jan 02, 2010 8:18 pm
paulmceleney wrote:IF its not a standard bike cut the trangler part of the frame off that hold the rear foot pegs on you can keep them and always have them welded back on you know you want to i would of done this but i also have a zed 1000 with a jmc fitted
It is a standard bike that I have owned since the late 70's so I would hate to spoil it by doing anything that drastic :shock: If it had been another bike I would have done it straight away.
KWACKERZ1
#10 PostAuthor: KWACKERZ1 » Sun Jan 03, 2010 2:24 pm
Talk to Dave at z-power and explain the problem, they are pretty reasonable there and if they wont refund you they may give you a credit note instead.
JMC Are defo off my list after it took me 6months to get my bearings from them plus 20 or so phone calls.
Steve R
#11 PostAuthor: Steve R » Sun Jan 03, 2010 6:09 pm
Hi Martin,
I bought a new one a couple of years ago, crap service , 9 months waiting for it, bits missing when it did arrive.. Then it did not fit between the frame tubes until a bit of surgery and like yours hit the footrest mounts, well actually the round bosses where the standard exhaysts f]would fit. I used an angle grinder and ground off 5mm of the inside of each boss which made it fit. JMC were no f~~~~g help at all.
I WOULD NEVER EVER BUY ANYTHING OFF THEM AGAIN!!!!
martinz1b
#12 PostAuthor: martinz1b » Sun Jan 03, 2010 6:24 pm
Steve R wrote:Hi Martin,
I will be doing the same because I want the back end tightening up a little, I will be very careful before I buy any more aftermarket bits during the rebuild. :evil:
KWAKERZ1, I will not bother Dave because it looks like it's the norm for these arms not to fit a standard frame and it is quite hard to find a swinging arm with the brake drum fittings nowadays. There should be a naming and shaming section on the site to let members know of problems they may encounter :smak
coldsummer
#13 PostAuthor: coldsummer » Sun Jan 03, 2010 7:10 pm
I ordered one ages ago. Should have been ready by November. Not heard a dickie bird yet.
neilbarrett
jmc
#14 PostAuthor: neilbarrett » Sun Jan 03, 2010 9:19 pm
had 1 about 20yrs ago,never touched 1 since
Russ
jmc
#15 PostAuthor: Russ » Mon Jan 04, 2010 12:44 pm
Had a mono shok specially made by JMC for mine. No problems... its great. Lots of dosh though.
