z650/1000
z650/1000
2 days the day i start my new project it starts with a modified z650 f2 frame 2 take a z1000j motor the rear end is s/wing arm shocks,wheel and brake of a zrx1100 and afull front end of a 750 zepher ,standard tank and side panels will be retained and a tail unit from a z1000 a2, a2 4 seat has been cut down and modified 2 a single seat the exhaust is a one of consisting of kerker down pipes and a harris end can .zepher oil cooler front and az750 cooler rear will be added .torrossi rear sets,fork brace, steering damper will be added not made up mind about paint job yet ,? have promissed fer it for scottish bike show
so lots 2 do will keep youposted on progress
- paul doran
Re: z650/1000
Lonewolf wrote:2 days the day i start my new project it starts with a modified z650 f2 frame 2 take a z1000j motor the rear end is s/wing arm shocks,wheel and brake of a zrx1100 and afull front end of a 750 zepher ,standard tank and side panels will be retained and a tail unit from a z1000 a2, a2 4 seat has been cut down and modified 2 a single seat the exhaust is a one of consisting of kerker down pipes and a harris end can .zepher oil cooler front and az750 cooler rear will be added .torrossi rear sets,fork brace, steering damper will be added not made up mind about paint job yet ,? have promissed fer it for scottish bike showso lots 2 do will keep youposted on progress
are You going to do a Big Chief Thundercloud on it James?
