Z1000J front engine mount.
#1 PostAuthor: Ginger Bear » Sun Dec 06, 2009 12:36 pm
I am looking for a front engine mount to fit a Z1000J. The one pictured is from a GPz1100 Unitrac. The holes where it mounts to the frame are at different 'centres' to the holes in the frame. :shock: Image
# 104
#2 PostAuthor: Al » Sun Dec 06, 2009 1:09 pm
Sorry GB once again i cant help however this is the one off mine and if you want to make or have made your own i can send you the dimensions or the plate to copy.
#3 PostAuthor: Ginger Bear » Sun Dec 06, 2009 1:29 pm
Thanks Al.
Making my own is plan B, so if that's the way I have to go, then dimensions would be very useful!
# 104
#4 PostAuthor: Al » Sun Dec 06, 2009 1:36 pm
Looks like the unitrack one has a larger off set than mine.
See reply to 'spacer dimensions' in your bike help thread for possible explanation reference horseshoe shaped spacer!
#5 PostAuthor: Al » Sun Dec 06, 2009 6:28 pm
As promised in pm.
GB any trouble reading the numbers give me a shout.
#6 PostAuthor: Ginger Bear » Sun Dec 06, 2009 9:07 pm
Thanks for taking the time to do that Al....... Cheers GB.
# 104
#7 PostAuthor: Ginger Bear » Thu Dec 17, 2009 9:08 am
Now sourced........ Thank you elr-21
# 104
