Dismantling carbs and cleaning.
Rob Lafferty
#1 PostAuthor: Rob Lafferty » Mon Nov 30, 2009 7:11 pm
Have taken the carbs appart as far as possible so that they can be vapor blasted, but there are a couple of brass parts that cannot be removed easily.
Is it safe to have them cleaned with the brass bit still in place ?
What is the best way of removing 15 year old petrol for the other parts if i dont have an ultra sonic cleaner ?
Thanks for the help.
hal
#2 PostAuthor: hal » Mon Nov 30, 2009 7:17 pm
Just soak the parts in cellulose thinners. works a treat !!
Z1B Alan
#3 PostAuthor: Z1B Alan » Mon Nov 30, 2009 9:46 pm
Rob I have just had my carbs ultrasonicly cleaned by Ginger Bear cost very very reasonable and a superb job I strongly recomend you pm him
its the only way to be sure they are realy clean.
