Does new plate stick to old Cadmium/Zinc? HELP Please
Spokes?
I use brick cleaner from b&q or wickes to strip the zinc from metal parts before replating.The problem with zincing is the platers will strip and plate the part whether it is pitted or not so this is a quick and easy way to strip back to clean bare metal so that you can prepare the surface yourself.Remember nobody loves your bike more than you so a bit of elbow grease will help to avoid disappointment when they are replated.
