Removing cylinder head bolts Z1100R
Magnum1
#1 PostAuthor: Magnum1 » Fri Nov 13, 2009 5:35 pm
I'm about to remove the head from my engine and I'm a bit concerned about the 2 cylinder head bolts. They look like they're waiting to snap! Anyone got any advice on removing them please?
Thanks,
Rod :(
#2 PostAuthor: Ginger Bear » Fri Nov 13, 2009 6:32 pm
Just don't do it tonight, Friday the 13th and all that...... They're bound to snap. Wait till tomorrow.
# 104
Keefleaf
#3 PostAuthor: Keefleaf » Fri Nov 13, 2009 9:59 pm
Blow torch might be a good idea :idea: .Heat them up to expand .
tlc
International Rep
#4 PostAuthor: tlc » Fri Nov 13, 2009 10:11 pm
My tacho housing bolt is as stuck as a very stuck thing but I am confident it will move with a blowtorch and some patience.
I`ll let you know when..........................
.....................it`s snapped :cry:
Asphalt Cowboy
Magnum1
#5 PostAuthor: Magnum1 » Sat Nov 14, 2009 9:04 am
I'm just gonna keep looking at it for a while.
Rod
02GF74
#6 PostAuthor: 02GF74 » Sat Nov 14, 2009 10:59 am
is heatingthe answer? bolts will be steel but engine is aluminium alloy - the latter will expand more than steel when heated thus making it tighter?
run a scriber between bolt/head interface and apply penetrating fluid - not ~WD40. aloow to soak. the fluid may lubricate the bolt head as you undo it.
.... but chances are it will snap if it looks like its gonna :(
Magnum1
#7 PostAuthor: Magnum1 » Sat Nov 14, 2009 11:45 am
Thanks for the advice, I gave them a little tweak and they came out easy. Maybe it was the leaky cam cover that kept them all nice and oily!
Anyway, I'm going to switch to a project from now - looks like its going to be a long one.
Rod
