Which Carbs?
- coldsummer
Which Carbs?
Trying to find some Z1A carbs with no success. I believe they are 28mm which are difficult to find. Question is, would the more commonly available 26mm carbs work, and are there any other options
- Surfdeneige
- coldsummer
Surfdeneige wrote:Simon, try the 34mm that are on it first unless it is an asthetics issue. Secondly I understand the only difference between the two is about reliability not performance.
I probably will Ken, just thought it would be nicer (looks and running wise) to have original carbs. Strange logic considering what I'm planning for the rest of it
- coldsummer
- coldsummer
- simon gilling
- Regular Poster
hi there, I fitted some 26mm carbs to my 1972 Z1, they physically fit ok, a bit deeper front to back but only a few mm. They run really nice, smooth even tickover, better,better low rev pick up than the 28mms and on a run 55-60 mpg at 70-80 mph. They may have clipped a little off the top speed, but the driveability at low to medium revs is where I use it most of the time.
Regards
Simon G.
Regards
Simon G.
Don't ask me, I just got here myself!
- coldsummer
simon gilling wrote:hi there, I fitted some 26mm carbs to my 1972 Z1, they physically fit ok, a bit deeper front to back but only a few mm. They run really nice, smooth even tickover, better,better low rev pick up than the 28mms and on a run 55-60 mpg at 70-80 mph. They may have clipped a little off the top speed, but the driveability at low to medium revs is where I use it most of the time.
Regards
Simon G.
Thanks Simon, that is interesting to know. Seems bigger isn't always better?
Users browsing this forum: No registered users and 85 guests
