Which Carbs?
coldsummer
Which Carbs?
#1 PostAuthor: coldsummer » Thu Nov 12, 2009 12:39 am
Trying to find some Z1A carbs with no success. I believe they are 28mm which are difficult to find. Question is, would the more commonly available 26mm carbs work, and are there any other options :?:
Surfdeneige
#2 PostAuthor: Surfdeneige » Thu Nov 12, 2009 8:26 am
Simon, try the 34mm that are on it first unless it is an asthetics issue. Secondly I understand the only difference between the two is about reliability not performance.
A ken fit like!
coldsummer
#3 PostAuthor: coldsummer » Thu Nov 12, 2009 9:43 am
Surfdeneige wrote:Simon, try the 34mm that are on it first unless it is an asthetics issue. Secondly I understand the only difference between the two is about reliability not performance.
I probably will Ken, just thought it would be nicer (looks and running wise) to have original carbs. Strange logic considering what I'm planning for the rest of it :wink:
ROZZER
#4 PostAuthor: ROZZER » Thu Nov 12, 2009 12:04 pm
Bike will run perfectly well (arguably better than the 28's)on the 26mm carbs from a Z900. If your not bothered about originality go for it or try carbs from Z1000/Z1R etc.
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
#5 PostAuthor: Rich » Thu Nov 12, 2009 5:04 pm
29mm smoothbores, but if you have 34mm CVs on try them. Go to Wired Georges site if you have trouble
coldsummer
#6 PostAuthor: coldsummer » Thu Nov 12, 2009 7:46 pm
Rich wrote:29mm smoothbores, but if you have 34mm CVs on try them. Go to Wired Georges site if you have trouble
Thanks for the advice. What/who is Wired George??
KWACKERZ1
wired george
#7 PostAuthor: KWACKERZ1 » Fri Nov 13, 2009 12:03 pm
WIRED GEORGE IS A CARB SITE WITH GOOD INFO.
http://www.wgcarbs.com/index.php?option ... &Itemid=27
coldsummer
#8 PostAuthor: coldsummer » Fri Nov 13, 2009 12:20 pm
Thanks KwackerZ1 I'll give that a good browse!
simon gilling
#9 PostAuthor: simon gilling » Sat Nov 14, 2009 5:17 am
hi there, I fitted some 26mm carbs to my 1972 Z1, they physically fit ok, a bit deeper front to back but only a few mm. They run really nice, smooth even tickover, better,better low rev pick up than the 28mms and on a run 55-60 mpg at 70-80 mph. They may have clipped a little off the top speed, but the driveability at low to medium revs is where I use it most of the time.
Regards
Simon G.
Don't ask me, I just got here myself!
coldsummer
#10 PostAuthor: coldsummer » Sat Nov 14, 2009 10:25 am
simon gilling wrote:hi there, I fitted some 26mm carbs to my 1972 Z1, they physically fit ok, a bit deeper front to back but only a few mm. They run really nice, smooth even tickover, better,better low rev pick up than the 28mms and on a run 55-60 mpg at 70-80 mph. They may have clipped a little off the top speed, but the driveability at low to medium revs is where I use it most of the time.
Regards
Simon G.
Thanks Simon, that is interesting to know. Seems bigger isn't always better?
