Lectron Carbs anyone had any experience using these?
I have just picked up a set of 40mm lectrons to use on my Z1000 race bike, I would just like to know if anyone has any experience using them? and if they are smooth enough to use on a race track, what the midrange is like etc, I know they are good on a drag strip, how do they perform under normal riding conditions? many thanks
If its not broken, fix it till it is
- ade woollams
hi there ,
i dont think you are going to find them of any use for track racing ,due to the fact that when you shut off for corners the vacumm build up will stop you from reopening the throttle again till the vacum has dropped off as it jams the slides which means slowing down .they where never designed for that use, drag race only.
they may just spit ya off in the corners .sorry
39mm kiehins would be better.
- Jeff Saunders
I had a set one time (courtesy of Hadleigh Custom), they just were a pig on the street - almost impossible to get to do anything under 5,000rpm. I would not recommend even attempting to use on a street bike.
