thanks muchly,
Please post photos of your oil cooler on here
just wanna see what you have used and how you have mounted it.
thanks muchly,
thanks muchly,
cheers, well it is a start. kinda wha I am planning.
the cooler you have is a mocal - you can get them in many places but ThinkAuto actually make them.
I am looking to fit something a bit less chunky so am looking a m/cycle coolers but the hoses would be routed over the head, as opposed to round the side - like what you have done.
I managed to get a brand new kawsaki 8 row cooler, dead nice but it may be a tad too tall as the speedo cable gets in the way. It also needs to be space away from tee frame since there is that triangule steering brace would stop any air flow.
02GF74 wrote:zed1015 - just noticed the oil line coming out of the cam cover - is that for an oil pressure gauge or what?
It's one of the four oil lines for the external cam oil feed system i have made. It supplies the cams with cool oil direct via the cooler rather than running it up the hot rear cylinder studs. See my Drouin supercharged zed in the projects section for more detail.
- steve bowdler
