kickstart spline
paulmceleney
Chunks
kickstart spline
#1 PostAuthor: paulmceleney » Wed Oct 28, 2009 6:39 pm
I would like to remove my kickstart spline from 1978 z1000 a2 do i need to take the engine out, or could i remove the sum with the engine still in the frame and remove it this way. Also what would i need to do to remove it is it a easy job i want to fit a ape blank off plate
#2 PostAuthor: chrisu » Wed Oct 28, 2009 7:03 pm
sorry paul - you need to split the engine..........
#3 PostAuthor: Pigford » Wed Oct 28, 2009 7:22 pm
Have a look at BRIAN450's project - he had the same thing :!:
#4 PostAuthor: Ginger Bear » Wed Oct 28, 2009 7:22 pm
It is possible to get a rubber blanking cap to cover the spline, I have just trawled ebay, but can't find any at the moment.
They do make a naked spline look a little tidier. :??
With a bit of luck someone here will point you in the right direction.
000zeds
#5 PostAuthor: 000zeds » Wed Oct 28, 2009 8:09 pm
Phone Z-Power 01942 262864 as they don`t list everything on web.
Zeds-R-Us
paulmceleney
Chunks
#6 PostAuthor: paulmceleney » Thu Oct 29, 2009 4:51 pm
Thanks for everyones help ive decided to split the engine just order a blank off plate from debben performance steve was very helpful with the question that i asked
