brake caliper question
knut
#1 PostAuthor: knut » Thu Oct 22, 2009 10:43 pm
hi, a question for the collective,while checking the front brake pads on my a4,i noticed there,s no shim behind the pad on the piston side,is this correct ? i checked a spare caliper i had and that was the same, going by the haynes manual i,ve got ( z1000 manual) it shows a shim :?:
confused or what :roll:
plus both the calipers have different looking pistons ,pictures below.
caliper fitted to a4,Image
spare caliper,Image[/list]
tlc
International Rep
#2 PostAuthor: tlc » Fri Oct 23, 2009 4:43 am
The first picture shows the piston with an insert inside which was designed to stop the squeal. If you buy a NOS piston it will not have this insert.
I have not seen the second piston in the pic before but could it have another type of insert ?
Sometimes when you buy pads they have the shim you are missing. Maybe ask Z Power next time you order some to send a set with the shim. The pad in that case would have a peg on it to secure the shim.
None of these things are necessary and none of them stop the squeal. Copaslip is the only thing that does !
Asphalt Cowboy
HowieD
#3 PostAuthor: HowieD » Fri Oct 23, 2009 12:31 pm
Hello,
My Z1-R had the second type of piston. I seem to remember reading it was to stop heat transfer from the Sintered Metal break pads that came into fashion about them.
Regards
Howie
CD185, Maggot, Z1-R, Horace
