Brake light
mikey
Brake light
#1 PostAuthor: mikey » Tue Oct 20, 2009 5:56 pm
While im waiting for carb repair kits to arrive thought
id do couple little jobs that need doing on the Z like
the stop lamp warning light which stopped working just before
i stripped the carbs, so took the cover off and the bulb
was blackened so put new bulb in it and it still don't work
which is just about right for my Z any ideas anybody why it dont work
tlc
International Rep
#2 PostAuthor: tlc » Tue Oct 20, 2009 6:12 pm
Could be the output device which is found under the tank just above the coils.
Sadly no idea how to test it.
Asphalt Cowboy
mikey
#3 PostAuthor: mikey » Tue Oct 20, 2009 6:54 pm
Ok cheers chris double dutch to me speak to me
brother hes a leccy wizard
Steve Cooke
#4 PostAuthor: Steve Cooke » Tue Oct 20, 2009 8:12 pm
Check the contacts on the stop switches are sound, fiddle with them whilst the brakes are applied.
BShaw
#5 PostAuthor: BShaw » Tue Oct 20, 2009 8:58 pm
Tap a few things with the blunt end of a screwdriver, that often works for me when I don't understand whats going on.
Baza
Big Fluff
#6 PostAuthor: Big Fluff » Wed Oct 21, 2009 9:09 am
BShaw wrote:Tap a few things with the blunt end of a screwdriver, that often works for me when I don't understand whats going on.
eXCELLENT... i LIKE THAT :P
Taffus
#7 PostAuthor: Taffus » Wed Oct 21, 2009 10:50 am
Does it work with people?
(\__/)
(")_(")Image
#8 PostAuthor: PAULJAC47 » Wed Oct 21, 2009 6:58 pm
Tlc is on the right track the device sitting under the tank is the outage relay only way to test is by substitution with a good unit though in the past i have used a 12v relay.This unit is more complex than it seems as if you get a blown stop tail lamp the indicator in the clock flashes!! you dont get this facility if you use a standard relay.They are no longer available as a spare only hope is to get a used unit seen them go for over $60 on US ebay.
Hope this helps Paul Jac.....
mikey
#9 PostAuthor: mikey » Wed Oct 21, 2009 9:12 pm
At that price if it is gone i can live without it :lol:
mikey
#10 PostAuthor: mikey » Thu Oct 22, 2009 1:29 pm
tailiftchris wrote:Could be the output device which is found under the tank just above the coils.
I know how to test it..............plug it back in and it works :rir :rir
Thats all it was it just came unplugged :roll:
#11 PostAuthor: PAULJAC47 » Thu Oct 22, 2009 3:46 pm
Result Mikey,Cheers Paul J....
tlc
International Rep
#12 PostAuthor: tlc » Thu Oct 22, 2009 6:31 pm
That`ll be $60 then Mikey :D
Asphalt Cowboy
mikey
#13 PostAuthor: mikey » Thu Oct 22, 2009 6:44 pm
cheques bouncing its way to you chris :lol:
