battery boiling
bunnysZ
Granny Magnet
battery boiling
#1 PostAuthor: bunnysZ » Wed Oct 14, 2009 8:17 am
I have had to fill my battery twice this year, the water keeps boiling away , what causes this.
first time 2 months ago it was empty, and again yesterday.
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Wed Oct 14, 2009 8:45 am
Bunny
Check the charge voltage on the battery terminals with motor running,should be 13.5-14volts.Anything over this points to a duff regulator or rectifier or the unit if its a combined one.
Regards
Steve
#3 PostAuthor: chrisu » Wed Oct 14, 2009 1:52 pm
sounds like the regulator is on the fritz. time to change for a combined one.......
Steve Cooke
#4 PostAuthor: Steve Cooke » Wed Oct 14, 2009 4:26 pm
Regulator.
tlc
International Rep
#5 PostAuthor: tlc » Wed Oct 14, 2009 4:27 pm
Get a combined unit and let me know how you get on !
Asphalt Cowboy
bunnysZ
Granny Magnet
#6 PostAuthor: bunnysZ » Wed Oct 14, 2009 5:57 pm
actually chris , i have one in the gge , will give you a shout when it needs fitting ,
plus some calipers that need the rusted pipes taken out and some spokes that need taking off the wheels and a some bearings replaced inthe wheels and and and . :D
Guest
#7 PostAuthor: Guest » Wed Oct 14, 2009 6:00 pm
Had the same thing on my KZ1000A2 a few years ago fitted a new Regulator no more probs with the battery....
02GF74
#8 PostAuthor: 02GF74 » Wed Oct 14, 2009 7:04 pm
regulator.
on A1 and earlier (maybe later models) the rectifier and regulator were 2 separate units ,one found under each side panel.
wait until this weekend when I will hopefully get time to fit a solid state onece piece from a GPZ550 .... wanted to do it earluer but shit at worked means I am getting home late ... :( ... cost a tenner of ebay - read on here and someone fitted one from CG 126 ... or you can buy replacement Z unit for £ 70.
m1ks
#9 PostAuthor: m1ks » Wed Oct 14, 2009 7:04 pm
definitely your regulator boiling the battery dry, get it changed ASAP and replace the battery too, the old one will be well and truly shagged by now, you're lucky it retains a charge at all.
12V multimeter across the battery terminal should show a relatively steady charge between 13.5V and 14.5V MAX, anything over and that's bad
tlc
International Rep
#10 PostAuthor: tlc » Wed Oct 14, 2009 7:58 pm
bunnysZ wrote:plus some calipers that need the rusted pipes taken out and some spokes that need taking off the wheels and a some bearings replaced inthe wheels and and and . :D
I really don`t understand how your 900 won so many prizes this year then :??
Asphalt Cowboy
