http://www.quality-cycle.com/truth_abou ... chains.htm
Bike Chain Info
Bike Chain Info
Might be a good read before you buy your next C&S set
Re: Bike Chain Info
Pigford wrote:Might be a good read before you buy your next C&S set![]()
Thanks Pigford.
Very interesting, I bought a cheaper chain (Heavy Duty non ring) because the mileage I would be doing on my bike when it is finished would be minimal. It is an Iris 630RX and it has a tensile strength of 9240lbs so is nearly at the top end of the guide. That article has changed my mind about ever getting an overly expensive (overpriced) chain again.
- simon gilling
- Regular Poster
thanks for this info,
I wanted 'x' ring chain on my Z1 in 2000, found that 630 pitch was only in available in 'O' ring at best. So I fitted an 530 gearbox sprocket (17 tooth) from a VN800 and got B&C to make up a 38 tooth rear sprocket, finished off with a D.I.D. chain. It has run well for many years, no real wear, smoother and lighter.
I have some info for compatible 530 pitch sprockets from Z1 to 1000J including offsets, all available 'over the counter'.
Maybe the nudge I need to write a fresh report, there is also a really good site at jtssprockets.com where you can check the specs. of your existing gear shaft splines etc. and check out alternatives.
By the way although I agree that you should lube a chain from the inside of the links, I wouldn't like lube on my tyre, like in the picture.
Simon
p.s. I am sure that I read in the latest magasine that Will (Saxon Turbo) used a 19 tooth 530 gear box sprocket, I'd like to know if he had to mod anything to fit it.
p.p.s.
I read somewhere that you should always choose sprockets teeth numbers to avoid the chain pitches always running over the same sprocket teeth.
Simon
p.p.s.
Don't ask me, I just got here myself!
Andy230262
- Regular Poster
- Geoff Meager
- ZedHead
