trick z1000
#391 PostAuthor: Ginger Bear » Mon Sep 14, 2009 7:31 pm
Very Tidy Brian, It's all downhill now!!
brian 450
#392 PostAuthor: brian 450 » Tue Sep 15, 2009 8:23 am
Thanks lads. Should have engine painted next week then it will take shape fairly quick :hoo :hoo Have got some bolts being zink plated should have them back wed, I am sending some bits to Mikey today for him to do his magic, Then i will be making some billet engine mounts and some yokes,
brian 450
#393 PostAuthor: brian 450 » Wed Sep 23, 2009 3:52 pm
Painted is painted now :D :D Its going to sit in the oven over night to bake it on. Then i will be fitting it as soon as i get my bloody bolts back!!!! from the platers I was told it was a week turn around and they have had them a month so far.
brian 450
#394 PostAuthor: brian 450 » Thu Sep 24, 2009 8:32 pm
Engine is ready to fit now top end has been checked and is ok :D It has had a coat of etch primer and 3 coats of satin two pack and has been left in the oven all night at 35 deg to bake it on , Iam very pleased with the end result!!! :xbou
brian 450
#395 PostAuthor: brian 450 » Thu Sep 24, 2009 8:32 pm
brian 450
#396 PostAuthor: brian 450 » Thu Sep 24, 2009 8:34 pm
brian 450
#397 PostAuthor: brian 450 » Thu Sep 24, 2009 8:36 pm
brian 450
#398 PostAuthor: brian 450 » Thu Sep 24, 2009 8:37 pm
mikey
#399 PostAuthor: mikey » Thu Sep 24, 2009 8:49 pm
Looks very nice brian, doing your polishing tomorrow first chance had all week been flat out not complaining though.
GUYZED
#400 PostAuthor: GUYZED » Thu Sep 24, 2009 8:53 pm
WOW :shock: :shock: the engine looks brilliant now Brian.
#449
Z1000A2 Z650B1
phil churchett
#401 PostAuthor: phil churchett » Thu Sep 24, 2009 8:56 pm
Lovely Brian, bet you're glad you persevered with it now.
Don't scratch that motor when you put it back in the frame, will you :!:
brian 450
#402 PostAuthor: brian 450 » Sat Sep 26, 2009 5:16 pm
Got engine in today :D Rapped frame in thick paper car panels get deliverd in.
brian 450
#403 PostAuthor: brian 450 » Sat Sep 26, 2009 5:20 pm
brian 450
#404 PostAuthor: brian 450 » Sat Sep 26, 2009 5:24 pm
brian 450
#405 PostAuthor: brian 450 » Sat Sep 26, 2009 5:26 pm
