carbs for st
Redbeard
carbs for st
#1 PostAuthor: Redbeard » Mon Sep 21, 2009 7:30 pm
anyone got a good set of st carbs (28mm) or any that'll work instead? some of the float bowl threads are knackered on mine and one just won't tighten down enough to stop leaking. could they be helicoiled? thanks.
1979 Z1000ST
Steve Cooke
#2 PostAuthor: Steve Cooke » Mon Sep 21, 2009 9:04 pm
They can be Helicoiled quite easily the size is M4 X 0.7 pitch
#3 PostAuthor: zed1015 » Mon Sep 21, 2009 9:36 pm
There's also enough meat on the castings to drill and tap to M5.
Redbeard
#4 PostAuthor: Redbeard » Tue Sep 22, 2009 4:12 pm
Brlliant thanks guys!
1979 Z1000ST
outlaw
#5 PostAuthor: outlaw » Tue Sep 22, 2009 7:59 pm
hi, why not try and use a small nut and bolt to see if it stops leaking,
