z1r tyre sizes
watty
z1r tyre sizes
#1 PostAuthor: watty » Tue Sep 15, 2009 5:10 pm
Anyone help with tyre sizes for a 1978 z1r standard wheels as i have two sets and the tyres are different sizes.
Should they be front 100x90x18
rear 120x90x18
cheers
watty
ps any recommends for replacements
#2 PostAuthor: Pigford » Tue Sep 15, 2009 5:30 pm
That front tyre could be a bit of a squeeze :shock:
19" front :wink:
phil churchett
#3 PostAuthor: phil churchett » Tue Sep 15, 2009 6:13 pm
Later ones i believe used an 18" wheel.
#4 PostAuthor: Pigford » Tue Sep 15, 2009 6:45 pm
Ahhhhhhhhhh.............. seem to think you're right Mr Churchill :wink:
Kev1R
#5 PostAuthor: Kev1R » Tue Sep 15, 2009 7:51 pm
Its the later ones that had 19 inch front wheel (D2) model.
(which we didn't really see in the uk - although there are one or two about now!)
lta01
#6 PostAuthor: lta01 » Tue Sep 15, 2009 8:03 pm
sounds like the same sizes as I put on mine recently. I fitted Avon Roadriders, which seem to give very stable handling, wet or dry. I used to use BT45's , but was encouraged by Tony Salt ( former GP tyre man for Michelin ) to try these ; good advice I think.
He who dies with the most toys wins .
popsA1
#7 PostAuthor: popsA1 » Tue Sep 15, 2009 8:04 pm
My Kawasaki workshop manual covering A1, A2 and D1 shows 3.50H-18 front and 4.00-18 rear for the D1.
tlc
International Rep
#8 PostAuthor: tlc » Tue Sep 15, 2009 8:07 pm
We seem to be getting lost here :??
Front is 3.25V19 4PR
Rear is 4.00V18 4PR.
I reckon it is most important that you do not use modern metric tyres as the rims are suited to the higher profile imperial sizes.
Everyone seems to like the Bridgestone BT45`s and after a certain amount of deliberation I plumped for them too.
Best mod I ever gave to a bike !
Posted this after the two sensible replies. I would agree that the 18 is a slightly wider tyre at 3.50 !
Asphalt Cowboy
#9 PostAuthor: chrisu » Tue Sep 15, 2009 8:28 pm
Z1RT311 wrote:Its the later ones that had 19 inch front wheel (D2) model.
Is the correct answer.
My (now Keiths) Z1R-D2 has a 19 inch front wheel - earlier ones were 18 inch.
KeithZ1R
#10 PostAuthor: KeithZ1R » Tue Sep 15, 2009 8:28 pm
100 90 18 F ..... 120 90 18 R ...... unless you have a 19 inch front wheel then adjust front to suit .
Metzler lazertech give the best milleage (in my opinion) and they dont break the bank especially if you go for the H rated which are more than adequate :!:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Ed Z1-R
#11 PostAuthor: Ed Z1-R » Tue Sep 15, 2009 10:22 pm
BT 45's on mine,so far so good :up
Donaldson
#12 PostAuthor: Donaldson » Fri Sep 18, 2009 2:33 pm
Just got 6500 out of my back BT45 v rated, still like to use the top end every so often :D
